1995 Trojan 350 Cruiser
- emk101
I think they hold up well and the first and last things to go on that boat were the engines, which could have been replaced/rebuilt. They were volvo penta's I believe, but this was some time ago.
We are between 2 boats seriously, maybe a third. I wanted to hear from some people who have or have had a 95' Trojan 350 Cruiser.
This one is:
Asking ~43k
Twin 454-XL Cruisaders
675 Engine hours (twin Inboards)
35ft
12ft beam
The hull is stated as "fiberglass reinforced"
Genset, AC/Heat, Ice maker on deck, fridge on deck, sink on deck, full camper canvas (replaced 4 years ago)
Vacuflush head
Head pump and water heater replaced 2 years ago
**The one thing I saw on the boat was water intrusion around the windows in the V-berth. There was a decent amount of it.
We've seen this boat. It has all the bells and whistles. Upholstery doesn't need to be re-done. Everything seems clean.
There was no musty odor, no gas smell in the engine compartment.
It's in dry storage right now though.
Questions:
Is this boat cored or not?
Anyone own this boat and can give me a review of how it's been holding up?
Anything to look out for with this boat?
I've never had Crusader engines, how do they stand up to the hours?
Good/Bad?
And lastly, if anyone knows, how do these boats handle with the crazy weather we get over the great lakes -- I'm on lake Ontario and had to get back to port in 10 ft rollers the other day, on an 18 ft century bowrider (which is one of the things that has us wanting a larger boat).
***We plan on getting a survey done, compression test, and having our independent mechanic check it out before purchase. We're being very picky and have seen close to 30 boats so far.
I've attached photos of the water damage and the over-all boat
(Side note, this boat is built by Carver. Trojan forum told me to go to a Carver forum).
Re: 1995 Trojan 350 Cruiser
Your F32 (very popular model by the way) would have been a repower if it had Volvos in her. I don't believe Volvo was an option unless something unique was commissioned off the assembly line for some reason.
The F32 would have been solid glass, I don't think the 350 is though. Your surveyor will be able to tell. The water leak may or may not be a big concern. If it's cored in that area, it's a problem if water has leaked into the core, otherwise it's a matter of removing the portlight and re-bedding it, not all that uncommon.
Crusader puts together a good package. They're all GM blocks though and the 454s are easy to get parts for. Other than fuel consumption and leaking rear main seals, they're a good engine. How many hours?
The key is getting a survey done, and if the boat spent any time in salt water, you want to be extra diligent in it's assessment. She'll likely have the usual "high moisture" areas around the bow, pulpit, stanchions, and anywhere else that has hardware fastened to the deck, and perhaps the swim platform may show signs of moisture but for that age, you'll find the same on probably 90% of boats of any brand. Don't know the stringer system used but if it's wood stringers, that's an important check and can be pricey to replace if they're bad.
Hopefully a member here that may have the same model will chime in with structural and handling feedback.
Good luck, and let us know how it goes.
I would image they are built like other carvers of the same era with no wood below the water line, but I am not certain. Do some research and hire a good surveyor.
Good luck!
- Been thanked: 654 times
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
Look around a bit - you might find something - especially if you are willing to do a little TLC:
Carver 3227 for $12K
http://www.ebay.com/itm/Ebay-Motors-Boa ... Kk&vxp=mtr
Carver 3607 for $22K:
http://www.ebay.com/itm/1988-Carver-360 ... 3I&vxp=mtr
And I've got a friend with a 34 Hatteras for $25K here in NC...
Lake Norman, NC
Carver 3227 - "Splashy Lady"
- mjk1040
- Been thanked: 248 times
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Users browsing this forum: Google [Bot] and 18 guests
