New to us...El Grande Chancho... 3607aft
Been thanked: 491 times
Re: New to us...El Grande Chancho... 3607aft
Postby waybomb » March 18th, 2019, 9:06 am
Great story.
Welcome aboard!
Postby km1125 » March 18th, 2019, 1:22 pm
Congrats!!
I have an older version ('83) of the same boat and have enjoyed it for many years. In your description you didn't include the one very unique feature... A TUB!! (not that you could really use it though!)
Curious what happened on your steering and if you have a dual station. What did it take to complete your trip?
kamakazerc
Vessel Info: proud new owners of a 1988 3607 aft cabin,as of august 2018, and still have at this time our 1980 mariner 2896
Has thanked: 3 times
Been thanked: 8 times
Postby kamakazerc » March 19th, 2019, 3:17 pm
Hi KM. So, what happened with the helm issue was, that the upper helm was leaving hydrolic fluid. Yes I do have dual helms, but they both work off the same hydrolic system and reservoir , so all steering was compromised. So when we made port, I tore down the upper helm pump, very carefully....which is part of the shaft assembly. Looked it over to find that the final seal nearest the steering wheel, had failed. Well, of course no proper parts were available. So I mcgyvered it. Went to an auto zone, found a oring seal kit for something, that had what I thought may work . Came back and just piggybacked the bad seal. Reassembled. Refilled an pressurized the fluid resevoir. And by George, it worked. And is actually still is working! I found and ordered the correct seals and have them ready for this season.
So just shows, with a little enginuity, you can almost always make it to home port...!!!! :-)
Postby Viper » March 24th, 2019, 12:32 pm
kamakazerc wrote:Source of the post..,... seal nearest the steering wheel, had failed....
Pretty common failure point. Glad you got her going. Sounds like it was an awesome trip.
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 157 times
Postby ColRon » March 24th, 2019, 7:31 pm
Great story and congrats on the latest acquisition!
Ron
“Escape Plan”
Murray, KY
:usa:
Users browsing this forum: Google Adsense [Bot] and 52 guests
