1999 Carver 356 ACMY Bridge Enclosure
- Reidenjw
- Vessel Info: 1999 356 ACMY, 7.4L Mercruiser
Also wanted to see if anyone has ever mounted a transducer without pulling the boat successfully? Don’t really want to haul it out right now for putting a new Raymarine transducer on. Was just out with new bottom job. Didn’t know if anyone had any secrets or if carver had anything on the inside of the hull for shooting through. Thanks.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: 1999 Carver 356 ACMY Bridge Enclosure
There are "shoot through the hull" transducers you can use. My guess is they aren't as good as bottom mounted units
If you bought a thru-hull ducer, you're out of luck. Needs to be installed out of the water. If it's an in-hull design as buster mentioned, all the work is done inside the bilge. I agree there is nothing better than having the ducer in the water but there are some pretty powerful high tech in-hull units out there now. Which ever you have, propper install procedures will depend on your hull design.
Did you already purchase the ducer? If so which one? That will make a big difference in installation time.
- Reidenjw
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
