Fresh water pump
- 1992330aftcabin
- Vessel Info: 1992 330 Carver aft cabin
- Has thanked: 54 times
- Been thanked: 32 times
Fresh water pump
- mjk1040
- Been thanked: 248 times
Re: Fresh water pump
- Has thanked: 474 times
- cmlrfp
- Vessel Info: 2008 41 CMY
- Has thanked: 2 times
2012 41CMY
Thanks all
RP
cmlrfp wrote:Question on using dock water to pressurize your boat so you don't use the house tank..... I notice that when connected to dock domestic water supply my fresh water holding still goes down!!!! Is this normal or is there an issue with a check valve or something
2012 41CMY
Thanks all
RP
Yes, like others have mentioned, kill the potable water pump at the breaker. Your pump pressure is likely set higher than the city water pressure, just like mine. If you want that extra pressure for certain uses (like a nice shower or a good deck washdown) then kick the pump on and use up some of the tank water.
- 1992330aftcabin
Users browsing this forum: bud37 and 30 guests
