Bilge Fans - independent or ganged
- CaptBob
- Vessel Info: Shopping....
- Been thanked: 33 times
Re: Bilge Fans - independent or ganged
So... The main on the helm DC panel must on, then fan one must be on, then each of the other three can be controlled individually with the breakers. Why? I dunno. I just leave them all on all the time and hit the helm/gen switch to control them. As we run our genny pretty much all the time, I leave the blowers on from dock to dock.
More Nautiville 2004 Carver 360 Sport Sedan
A little less Nauti 2008 SeaDoo 150 Speedster (Admiral could not live without a jet boat....
)Nautiville 2005 Cruisers 280 CXi *Sold*
Nautitown 2012 SeaDoo 180 SP *Sold*
- Peter
- Vessel Info: Carver 38ss 2007
- Has thanked: 23 times
- Been thanked: 7 times
The generator fan that switches from the lazorrette panel doesnt seem to work now any ideas ?
Tomion
- Vessel Info: Carver 530
- Has thanked: 1 time
- Been thanked: 2 times
2001 Carver 444
- Keith S
- Vessel Info: 2005 38 Super Sport
- Been thanked: 21 times
Diesel boats do not require blowers to remove fumes, the blowers are used to control engine compartment temperature.
Therefore they usually draw air from the upper 1/3 of the compartment and may be controlled by a thermostat in the engine compartment. If a fire extinguishing system is installed, a means to shut down the blowers when the fire system activates must be installed.
Gasoline powered boats require the blowers to remove combustible fumes from the bilge. The blower intake must be in the lower 1/3 of the compartment but above the normal level of accumulated bilge water.
ABYC H2 specifies one blower per engine located as close as possible to the engine is serves. Multiple blowers must operate simultaneously with each blower provided with it's own over-current protection. Blowers must have a visual indicator other than switch position such as a light. H2 is 13 pages of more than you ever wanted to know about bilge blowers.
- mjmason1
- Vessel Info: 1999 Carver Voyager 530
- Has thanked: 2 times
- Been thanked: 19 times
- Sgodfrey
- Vessel Info: Carver 450 Voyager
- Been thanked: 9 times
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
However, one thing I did notice that was different than in all of my gas powered boats. The 2 blowers on the Starboard side blow air into the bilge and the 2 on the Port side blow air out, over the top of the engines. I was advised by mechanic, that this is to keep the air around the engine cool, clean in addition to removing fumes from combustion. So, if replacing blowers for any reason, be sure to install them the proper way.
Where as, with a gas engines the blowers draw air from down low in you bilge and exhaust them out of the boat for obvious reasons.
- gotjeepzj
- Vessel Info: 1986 Mariner 3297
Where is the shower discharge thru hull 3297?
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Where is the shower discharge thru hull 3297?
Carver is pretty good at hiding bilge access panels. Do you have carpeting on the floor just outside the head? If you do, try pulling it up, most likely, it is not glued down.
- mjk1040
- Been thanked: 248 times
Users browsing this forum: No registered users and 43 guests
