what oil to use?
- RWS
- Vessel Info: 1987 3607 aft
- Has thanked: 28 times
what oil to use?
Re: what oil to use?
Many other on this site will swear by the shell rotella.
I have stated on other posts, that I believe any good quality oil, changed at regular intervals will be fine for recreational marine use. The Mobile 1 or any synthetic oil, will not cause leaks. Time and operating, or sometimes more so, non operating conditions (gaskets and seals drying out from lack of use) cause leaks, not the oil itself.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
Lake Norman, NC
Carver 3227 - "Splashy Lady"
- Been thanked: 654 times
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
“Escape Plan”
Murray, KY
- Has thanked: 603 times
RWS wrote:Source of the post Needing input on what oil to use. We have an 1987 3607 with Merc gas engines with 340 hp which have about 1600 hours on them. We have only had this boat for a year. The previous owner had the boat for 7 years and in his last year he used a high mileage Mobile one auto oil for the yearly oil change. I used a diesel and gas marine grade oil, 15- 30 weight I believe . I have thought for years that using a synthetic oil in older engines could lead to oil leaks.What would you recommend we use? Compression check when we bought the boat showed 140-150 on all cylinders on both engines. What should we do for oil this season?
In general, oils specified as " high mileage "....may have seal conditioners etc to cut down on oil leakage on older engines. There are lots of good choices, but if you change ,keep and eye out for leakage , considering why the previous owner used high mileage oil.
- throwback2
- Vessel Info: 1987 Carver 28 Voyager,twin small blocks,1991 Shamrock,350 Chevy now.
and a few other water toys - Has thanked: 8 times
- Been thanked: 23 times
