22 X 22RH 1-3/8" Prop
- abcoker
- Vessel Info: 1993 Carver 350 Aft Cabin
454 Crusaders - Location: Lewisville Lake, TX
22 X 22RH 1-3/8"
Thanks,
Alan
454 Crusader XL
- Been thanked: 491 times
Re: 22 X 22RH 1-3/8" Prop
All of them, for my 2807, 4207, pv, and the 3697 were brand me unused.
This type of failure leaves a much different tell tale sign than one that fails due to stress alone. A trained eye would be able to tell from the end of the shaft that's left whether the failure was due to stress or the result of corrosion. You'd see half of the cavity in the end of the shaft with the surrounding material looking like it was twisted then torn. I've seen a couple of these, pretty interesting and surprising to see. Both were originally salt water applications, same goes for every prop hub I've seen like this, it's something I look for in SS hubs now if I suspect it's a salt water boat.
- Has thanked: 603 times
Also corrosion and electrolysis can play havoc with underwater metals that may have an underlying inclusion.
I'd also check craigslist.
Even if you get a more expensive one to get you through right now, keep an eye out for a set of spares on Craigslist and Ebay.
I bought my spare set on Craigslist for $300. (YES, a SET).
They aren't a perfect match for the boat, being a three blades instead of my stock 4 blades and they came form a old Chris Craft the owner had already sold but he still had his spares. However, I can't tell much difference in the performance. I've dinged props a couple times mid season and hauling the boat and putting on the 3 blades for the rest of the season is a couple hour job and I never lost days of boating. I gave the main props to the prop shop and let them take their time getting them back to snuff. Before the beginning of the next season I put the stock props back on.
- throwback2
- Vessel Info: 1987 Carver 28 Voyager,twin small blocks,1991 Shamrock,350 Chevy now.
and a few other water toys - Has thanked: 8 times
- Been thanked: 23 times
abcoker wrote:Source of the post My starboard drive shaft sheared off. Insurance says it was a mechanical failure so they aren't covering it even though I clearly hit something. I am finally moving forward with the repair but am trying to find a prop that isn't $1700. Any idea where I could find a used or reconditioned prop?
22 X 22RH 1-3/8"
Thanks,
Alan
Progressive insurance?
- captmiami
- Vessel Info: 1991 43 Carver MY
