Potable Water Pump Continuously Running
- Marty
- Vessel Info: 2000 326 AFT Cabin
- Has thanked: 16 times
- Been thanked: 9 times
Pump is likely original Shurflo, so would it be safe to assume this is a pump issue?
Re: Potable Water Pump Continuously Running
- Marty
- Has thanked: 603 times
- Marty
Also, after the screen, back your pressure adjustment screw out just a tiny bit until it stops.
- Marty
tomschauer wrote:Source of the post Check the inlet screen to the pump. Sometimes if there is some muck in there they can't build full pressure for some reason.
Will have to wait till next week, but will try the pressure screw as the screen looked clear to me.
Thanks,
Good pumps are getting more and more expensive and seem to be failing more often and sooner than their older counterparts. There are rebuild kits for most designs if you're willing to spend the time but the rest of the pump will still be old and susceptible to failure in the near future. A good cleaning though can sometimes solve what may seem like hardware failure.
My opinion here is get a replacement pump that fits the water flow spec you need and go with it. Perhaps the cheaper the better considering the quality issues of late.
