Add Shore Water Connection
- RussL
- Vessel Info: 2000 396 Motor Yacht
- Has thanked: 18 times
- Been thanked: 11 times
If I pull the recessed power box will the water lines be present, or is that wishful thinking? Things are pretty tight below and I am not sure I could fish a pipe back there....
- Has thanked: 602 times
Re: Add Shore Water Connection
- RussL
I would start by removing the electrical inlet to investigate what is behind and where you can make your hole. Simply snake down a length of pex and attempt to grab onto the end which should not be that difficult. The connection is simply Tee'd into any cold water line you can find back there. Snip and insert is all there is to it. A good pair of pex cutters makes everything very easy.
Here is a photo I took this weekend when I replaced the original poor functioning inlet.
- RussL
- RussL
- RussL
Does anyone know what it is specified to be able to support? I am guessing 50 PSI, but I don't want to guess....- km1125
Found this.
The SeaTech PEX tubing is produced from a high performance, cross-linked polyethylene material. SeaTech PEX tubing is formulated and manufactured in 3/8" CTS (1/2" OD), 1/2" CTS (5/8" OD), 3/4" CTS (7/8" OD), and 1" CTS (9/8" OD) sizes. SeaTech PEX Tubing is NSF listed, FDA recognized and available in multiple colors for ease of water line identification.
Specifications:
Operating Pressure: Vacuum to 160 psi
Max Temperature: 180º F @ 100 psi
Max Temperature: 72º F @ 160 psi
Coil Length: 250'*
Also known as: Watts 81902611
