WOT #
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
WOT #
What are you all running for pros and WOT? I know numbers don’t lie, but do i want to hit 4400 or stay in the middle.
Re: WOT #
The question you have to ask yourself here is how much do you really drive this boat at wide open throttle and the more important in my opinion is do you really want to push 26 year old engines like that. If you are considering saving any fuel, it won't happen......if you use all the HP the engines have available you will use the same amount of fuel, just physics. You may go a little faster therefore get there sooner, but what does the prop shop say....they have all sorts of calculators available to them nowadays to spec things out within reason I would think. You lower the pitch you will have a higher RPM at hull speed as well, so consider how each advantage applies to your needs.
There are many opinions about this WOT thing, this is just mine for an older boat.....new boat would be completely different IMO.
- tonyiiiafl
Re: WOT #
I NEVER run at WOT, usually between 2800 and 3200 for cruise. The prop shop said I would need to pitch to a 20 for WOT to happen. However, I am not looking for more speed, just a step at what the engines will not be working hard, hence the 21 pitch.
I am leaning towards leaving these at the 21 pitch and trying them as such next season. Then I can better decide if I want to go to a 20, stay at 21, or go back to a 22. Make sense?
Re: WOT #
- Been thanked: 654 times
Re: WOT #
- tonyiiiafl
Re: WOT #
- Has thanked: 474 times
Re: WOT #
While not applicable to a lot of Carver models, one also needs to ensure hull and transom cores aren't soaked and adding an enormous amount of additional weight to the equation.
Re: WOT #
