Polish & waxing
- Grafunkus
- Captain
- Vessel Info: 1982 33' Carver Mariner
1985 3607 Carver Aft Cabin - Location: Manitoba, Canada
- Has thanked: 63 times
- Been thanked: 32 times
Polish & waxing
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Polish & waxing
How to mark where you have already waxed? Most of the time, it is obvious, but if not, use "landmarks" on the boat...stantions, portholes, thruhulls on the side of the boat, etc. If you have the same bench, do the 3' you have access to and then move your bench to the next section.
It doesn't take long to figure these things out.
Edit....I took a look at Home Depot and they have a number of these benches in various sizes and heights, most under $100. I'm sure you can find one that would be a good fit for your needs. I bought mine specifically to use on my boat, but I have found it is really handy to have around the house.
- chpsk8
- Has thanked: 27 times
- Been thanked: 76 times
Re: Polish & waxing
Your tools are going to be the difference between it really working and just getting frustrated. It's a lot of glass to polish, so you want to do it right.
My boat was ROUGH when I bought it. Here's a post that has some polishing results.
https://www.carveryachtowners.com/viewtopic.php?p=29010#p29010
I use a 3M wool bonnet on a rotary polisher.
Mine was so rough that a lot of it had to be wet sanded with 1500 grit.
Aquabuff compound was my step. It's a compound that cuts through the scratches and oxidation.
Last step is Meguires flagship wax. That should last a season if the UV isn't super strong by you.
Now that mine is much better/shinier I've changed my process a little. I use a finishing glaze between the aquabuff and the wax to give it a little more pop. My goal by spring of next year is to have it so glossy you can stand on the dock and see your full reflection. We're getting there.
Good luck, if you buy a rotary buffer (you should) get one that's light, it's a lot of overhead work.
- Been thanked: 654 times
Re: Polish & waxing
As stated you definitely won't have any problems seeing what you have just buffed. You'll be amazed and what this hard work will do for your boat.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Polish & waxing
Re: Polish & waxing
I hired it out the last two times and it was well worth it for the hull, considerable damage to the gel can take place if done wrong and consider the gel is only so thick so go carefully with compounds and wet sand if this is what you choose to try.....just a caveat from me, as always my opinion......
