Bilge Blower Replacement on a 530
- Cricket
- Vessel Info: 2003 Carver 530 Voyager Pilothouse
- Has thanked: 2 times
- Been thanked: 2 times
So, none of my four bilge blowers on my 2003 530 are working. It me a while to find them. The are wedged between the fuel tanks and the hull with essentially no way to access them that I can see. Has anyone attempted such a repair?
many thanks
Tim
Re: Bilge Blower Replacement on a 530
I guess the bearings go after X amount of hours and they get really loud. Mine are a tight fit but accessible, another boat project.
- Cricket
Cricket wrote:Source of the post I agree that it is suspicious that all have failed. However, the aft head blower and the blower over the range have also failed so perhaps these were subpar to begin with. It is just as difficult to get to the wiring as the blowers themselves. As best I can tell the only way to access them would be to cut a hole in the cockpit above them. Alternatively, one could fit blowers on to the ends of the pipes that enter the engine room just aft of the engines. This would have been a much better place to put them.
I agree, good idea to abandon the impossible to get to ones and reroute hoses to a more accessible location for the new blower motors, hose can be run easily to where it needs to be IMO.....
- rcoff512
- Vessel Info: 1999 Carver Voyager 450
Home Port, Long Island NY USA - Has thanked: 12 times
- Been thanked: 8 times
- Contact:
The power for them also is also controlled by the ignition switches and then through the Fireboy (engine room automatic fire extinguisher) system so in case of engine room fire they shut down as to not feed the engine room with more oxygen during a fire situation.
You have several areas to check for + 12V continuity and ground continuity. Be careful probing the Fireboy system, I've heard they can be set off inadvertently.
Rich
- mjmason1
- Vessel Info: 1999 Carver Voyager 530
- Been thanked: 19 times
- mjmason1
- mjmason1
Users browsing this forum: No registered users and 40 guests
