1976 Carver Mariner 3396
- Gmnellis
- Vessel Info: 1976 Carver Mariner 3395
- Has thanked: 1 time
- mjk1040
- Been thanked: 248 times
Re: 1976 Carver Mariner 3396
- Been thanked: 491 times
What's directly above it?
Nothing wrong with making a new access panel.
Looks like the WH is at the transom under the storage area. There may be an opportunity to gain or create access from/through there if that space is wide/deep enough but from the pic, it looks like the unit is right up against the transom so it sits right under the front wall of the transom above deck. How much room is there between the port engine and the side hull?
Why does it need to be replaced? Can it not be repaired? If it can't come out without removing an engine, is there a space elsewhere in the boat to install a new one and simply leave that one there or cut it up and remove it in pieces as Mike suggests. If you dismantle and remove the cover and fittings, the actual tank itself might come out on its side if you have room to tilt it under that support on top. Hard to tell how much room there is between it and the engine or bell housing. It won't be an easy one!
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
- MistyRiver
- Vessel Info: 1976 Carver Santa Cruz 2866
Ford 351 Single Engine Inboard - Location: Kingston, Ontario
- Been thanked: 2 times
- KandJ72
- Vessel Info: '76 Carver Mariner 3395
Twin 351W Vdrives
Refit in process - Location: Central NY
- Has thanked: 20 times
- Been thanked: 3 times
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Users browsing this forum: No registered users and 47 guests
