Engine compartment blowers
LetGoJones
Vessel Info: 2004 Carver Three Six
Postby LetGoJones » May 19th, 2021, 12:30 pm
Hello working on my 2004 Carver 36 and the engine compartment blowers are not getting power, I have power at the helm switch and cabin panel but no power to the blower motor themselves, I fed 12v with a power probe directly to the motor and the blower worked? So I checked the ground on the bus bar and it's good? So where could be the problem?
Re: Engine compartment blowers
Postby Midnightsun » May 19th, 2021, 12:31 pm
Did you check the blower breakers?
LetGoJones
Postby LetGoJones » May 19th, 2021, 12:36 pm
Yes, checked and there's voltage
LetGoJones
Postby LetGoJones » May 19th, 2021, 12:37 pm
Is there some type of inline fuse or a relay?
Postby Midnightsun » May 19th, 2021, 12:48 pm
If the voltage is coming out of the switch, it's normally a free run right to the blower. Odd for sure. You cannot trace the wire from the switch to the blower?
LetGoJones
Postby LetGoJones » May 19th, 2021, 1:38 pm
The wire is identify as F2, there's a F2 tag at the beginning of the wire and at the end, it runs behind the panel down a whole of combined wires down a hole between the panel and the tv and disappears, what do you rec I do?
Postby g36 » May 19th, 2021, 1:46 pm
Since we're assuming the POS side is good an easy thing to do is running a temporary Negative wire to a house or engine battery or known good ground somewhere by the blower and try running the blower
Postby bud37 » May 19th, 2021, 1:49 pm
LetGoJones wrote:Source of the post The wire is identify as F2, there's a F2 tag at the beginning of the wire and at the end, it runs behind the panel down a whole of combined wires down a hole between the panel and the tv and disappears, what do you rec I do?
Do you have 4 blowers? If so check out this schematic, section 2....... it seems to show relays and a master ?
https://carveryachts.blob.core.windows. ... 3428v1.pdf
Postby bud37 » May 19th, 2021, 1:50 pm
If you have the Mariner with 2 blowers then they seem to be just a switch / breaker then the blower itself.....
Postby bud37 » May 19th, 2021, 1:54 pm
Check this out also..... May not apply to you ...but....
.viewtopic.php?f=12&t=1193
