bow thruster
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
bow thruster
1994 390CPMY
https://shop-us.sideshift.com/collectio ... w-thruster
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: bow thruster
- tonyiiiafl
Re: bow thruster
Re: bow thruster
- tonyiiiafl
Re: bow thruster
- tonyiiiafl
Re: bow thruster
Re: bow thruster
Your conditions and application will require installation to suit. One more thing to remember on these units which is not mentioned anywhere. The shaft seals should be replaced every 5 years as preventative maintenance. They are small and easily replaced and inexpensive with aftermarket seals using the numbers on them. After 7 years my seals failed and ruined the motors, cost me $2500 for replacement! I had a very early unit so things must have improved. The newer units may be better but why chance it for a few dollars in seals. No seal lasts forever.
- Has thanked: 474 times
Re: bow thruster
FWIW, I'm not that crazy about the Sideshift for this application. I've seen the results of a few units taking hits that required major component replacements. The only installations I've seen that haven't been damaged by floating debris like logs were stern installations. I'm also not crazy about the exposed contacts and wiring, critters in my area anyway love that stuff. They are a less expensive option for sure and pretty easy to install which makes the system attractive for those that don't have the budget for in hull thrusters. They're well made too, it's all pretty robust hardware, and they've overcome a few electrical issues and problems with the seals over the years. It's a good company to deal with, they're local for us, and will actually come out and do the install but I don't know how much territory they cover. If you're doing it yourself, don't skimp on the quality of caulking, and when you order, make sure the anodes are compatible with your water type. In your case (salt water) they should be zinc.
- Has thanked: 603 times
Re: bow thruster
Certainly, considerably cheaper than an in hull. Pat said he had been flown to different areas to do installs, extra cost for that though if they would even do that now.....
I think the Cadillac would be the in hull, but like everything, for them to work properly and not affect hull performance they need to be installed and wired correctly.
- tonyiiiafl
Re: bow thruster
Code: Select all
t isf I used the 12V model, I have an extra bank off of my 12V promariner 40A charger that is unused. and I could also hook to alternator power for engine recharge also. I am ready to pu[code]sh the b[code]utton this weekend, just [code]need to [code]figure out 12V [code]or 24v.[/code][/code][/code][/code]Return to “General Repairs & Maintenance”
