Charging 12V house batteries underway
Re: Charging 12V house batteries underway
Postby km1125 » March 13th, 2022, 5:31 pm
brow_14 wrote:Source of the post Thank you km1125
- I don't know how old the batteries are, I just bought the boat and had a mechanic inspection and survey done with no reported issues on the batteries (doesn't mean they didn't catch it)..., but I will check the house battery- Thank you!
is that to say that the house battery will be charged by the shore power as well?....or does the house battery get charged by the generator?
- to answer your question on the compressor, I believe it is the horn compressor ...can that we switched of (at night)?
I doubt the surveyor checked the quality of the batteries. I don't know any who do. Unless they had obvious visual clues that there was an issue (like badly corroded cables or connections), they wouldn't have noted it. You should probably plan on replacing it and also checking the engine start batteries. See if you can at least determine how old they are - perhaps there are stickers on the batteries that show their manf date.
The generator should supply power to anything your shore power does, so that would include the battery charger for the house and start batteries. When the generator isn't running and you're connected to shore power, that same battery charger would still charge the house and start batteries.
Yes, if it's the air horn compressor, you could certainly turn it off. There should be a dedicated circuit breaker on the 12VDC panel. If it periodically runs, they means you have a air leak somewhere, so someday when you're poking around on the boat, find the compressor and the lines to the horns and see if something is loose.
Postby bud37 » March 13th, 2022, 7:20 pm
Welcome to the forum...
Some things to check........ Are there any battery isolation switches in the bilge that are turned to off.......what happens when your main battery switch is turned thru the 1 then 2 then all. FYI ...Never turn this to off when the engines are running. All breakers and switches for the 12v system in the correct positions for use....check the manual for some hints.
Has this been like this since your sea trial ?
If so maybe you could get your surveyor/mechanic to come and help you with the power issue as one of them should have picked up a dead battery if that is the case here unless this has been going on for a while.....
Icango560
Vessel Info: 2004 Carver Voyager 560, 675 Volvo’s.
Postby Icango560 » November 14th, 2023, 8:39 pm
The circuit breaker for the 12v port charger is on the wall (hidden) behind the starboard engine near the oil changer panel.
Return to “Electrical”
