Stern Thruster
- GarryD
- Vessel Info: Carver 405, 1999 model, twin Cummins 375hp engines,
Stern Thruster
Stern Thruster
It's been a while so they may have changed things some but I was not crazy at the time with the solenoids they were using. They had a high failure rate so I would swap them out for better units right at the beginning. They were just your typical automotive starter solenoid so no issues finding better replacements.
If you contact the manufacturer directly, they will custom make the length of the tube for you which may help in certain applications. All my installations were to the transom not the swim platform, and found the installations to be pretty easy. Have also installed Side Power's external stern thruster (nice unit).
The only issues I have with the Side Shift is the motors and wiring being in the water, and no protection around the props. Other than that, they didn't seem to have a problem moving a 42' trawler.
Curious, why Side Shift? Is it just a price thing? A conventional stern thruster is pretty easy to install, has been around for quite a while, and proven itself to be a top performer. All you have to get past in your mind is cutting a large hole in your transom. If done right though, that should not be a concern.
- GarryD
Stern Thruster
Stern Thruster
http://www.imtra.com/a45d3762-8ca8-464e-be35-e75e74c033ac/side-power-thrusters-dc-electric-detail.htm
- GarryD
Stern Thruster
Stern Thruster
Keep in mind that the ST350 is a 24 volt unit. Unless you already have a 24 volt system on board, this will add an additional complication and expense. You would need to add an additional charger (24 volt), and if you want the battery bank to be charged while the engines are running which is the only way I recommend operating any thruster. Then you'de also need to replace one of the alternators with a 24 volt unit or find something on the market that would convert the current output to 24 volts. Replacing one of the alternators will add the additional complication of charging all 12 volt banks off one alternator and still maintain bank isolation. Can be done but a little more complicated and you loose redundancy of having a second 12 volt alternator but that's another thread.
I'll just ask; do you have a bow thruster? If you do, are the conditions such that you absolutely need a stern thruster? Unless you're trying to get into a real tight spot, fighting current, etc., with some practice using engines and just the bow thruster, you could overcome many conditions without the use of a stern thruster.
Not trying to talk you out of it, just putting it all out there so you have as much information as possible to make an educated decision.
- GarryD
Stern Thruster
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
Stern Thruster
My 506 is bigger, taller and wider. It is virtually a sailboat with with the enclosed hardtop. I only have a bow thruster, no stern thruster. I dock my boat stern in, and beside another vessel.
With diesels and a bow thruster, I wouldn't even consider a stern thruster, my wife stands on the swim platform and makes hand gestures to my back up camera. I use a combination of bow thruster and transmissions to make the boat move sideways - and it does exactly that. Port engine forward, stern reverse and left bow thruster - boat moves exactly sideways to port. Invert and it does the opposite.
Your boat will do the same thing.
Save your money. JMHO
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Stern Thruster
> If I can offer my 2 cents....
+1 Lyndon.
I get that it's all about conditions and one's comfort level though.
- Been thanked: 654 times
Stern Thruster
