2000 carver 406 AC thru-hull
- pondering50
- Has thanked: 4 times
- Been thanked: 3 times
Issue: AC thru-hull valve seemly only opens part way. Seems to shut off, just not open fully???. With both AC units on, one goes into high head pessure I think. Believe isue is not enough water flow to support both AC units.
Any options with handle (solid pulls does not budge it more than about 1/2 way to tab)
Can anything be done bottom side in the water? (help to open or validate amount of open)
To replace this thru-hull can it be done in the water or does it require haul out?
Any and all suggestions welcomed
Mark
Re: 2000 carver 406 AC thru-hull
- Been thanked: 654 times
It probably woud be pretty scary to try and replace while in the water, it could be done with some preparation but if your having a problem with it now there's no telling what might come up
- Has thanked: 603 times
- pondering50
Also after fully opened AC units, both worked fine.
Thanks everyone
Mark T
