Anchor Light
denpooch
Vessel Info: 2005 360 Mariner
Crusader 6.0 Captains Choice
Has thanked: 85 times
Been thanked: 89 times
Anchor Light
Postby denpooch » August 13th, 2022, 3:11 pm
Hey there everyone.
I was on the 'hook' and when I turned on the anchor light I did not get 360 white but just 180 aft light. When I switch to running, aft white stays and forward red/green power on.
Do you know if there are 2 bulbs in the mast?
I don't know if its a switch or bulb issue.
It will be good info to have prior to breaking out a ladder to get up there .
Also, are you guys replacing these bulbs with LED or keeping the original incandescent.
My vessel is a 2005 Mariner..
Thanks.
Re: Anchor Light
Postby km1125 » August 13th, 2022, 4:48 pm
Yes, there are two bulbs in those kind of combination lights.
You can typically replace with an LED, but you need a good quality LED, not just a cheap replacement. Cheap replacements might work but they expect a constant voltage and don't tolerate surges that great. Good quality bulbs will work the same over a wider voltage range and are preferred over the cheap ones especially for something as important as a navigation light.
Replacing both bulbs with LEDs would be desirable in an anchor light situation as they draw MUCH less power from the battery when on the hook.
Re: Anchor Light
Postby bud37 » August 13th, 2022, 5:21 pm
denpooch wrote:Source of the post Also, are you guys replacing these bulbs with LED or keeping the original incandescent
If you decide to change to led, a good idea IMO , check the CG regs in your area as the anchor light may need to be visible for a required distance.....some of the bulbs may have ratings, IDK for sure. Doesn't hurt to be in the know..
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Re: Anchor Light
Postby buster53 » August 13th, 2022, 6:43 pm
Chances are good that any LED equivalent will be at least as bright and probably brighter than the incandescent it replaces. And yes, I would replace any bulbs you have to LED, not just running lights, but interior lights as well.
denpooch
Re: Anchor Light
Postby denpooch » August 14th, 2022, 5:20 pm
Thanks everyone. LED it is!
