1984 Crusader 350 - Remote Fuel Filter replacement?
JeffandErin
- Vessel Info: 1984 Carver 3607 Aft Cabin
- Been thanked: 2 times
What the manual does not tell me is a part number to purchase the replacement filters.
I dont want to pull the cannister off to ttry to ID the filter - that will be my last option.
Hoping someone on this forum has the same engine / setup and can tell me what you filter you purchase / use to replace them
- plittle2005
- Vessel Info: 1992 Carver 350 Aft Cabin
- Has thanked: 16 times
- Been thanked: 37 times
Re: 1984 Crusader 350 - Remote Fuel Filter replacement?
You will have to remove existing element and visually compare. This is best done with a standard filter strap wrench. They can get quite tight, lubricate the gasket with motor oil when reinstalling.
However, they are not good for water separation. You should install a separator kit such as easily found on Amazon.
- plittle2005
However, they are not real water-separating filters. An aftermarket kit can easily be installed and give much better protection. ALL fuel has some water mixed in with it, from the marina tanks and your deck fitting leakage.
They also sell a kit that includes the element and the canister....# 18-7861
There may be an aluminum canister assembly out there but every one I've seen so far is just a coated metal. I've replaced quite a few that have rusted over the years. BTW, the Crusader OEM unit is not aluminum, but they were typically painted blue. Look at the other side of the label (English) on that canister in the pic, it tells you to replace the canister every year because it could rust and leak fuel.
- Has thanked: 602 times
JeffandErin wrote:Source of the post My Crusaders have the AC remote Fuel Filter Assemblies as described on page 7-6 of the Service Manual. Pic attached.
If you plan on keeping the boat, my advice would be to install a Racor/or the like, water separating filter system on each engine....it will be expensive but worth it in the long run.
See there I go spending money that is not mine....
