2004 570 pilothouse shaft struts and stuffing boxes
Topic author New Zealand
Cary Johnson
Vessel Info: 2004 570 pilothouse ,d12 Volvos 2 1/2” shafts
Postby Cary Johnson » October 26th, 2025, 11:01 pm
Hi there
I am on the hunt for 2 2 1/2” shaft struts and stuffing boxes for a 2004 570 pilothouse which is running D12 Volvos with 2 1/2” shafts. Any ideas where I could track some down?
Re: 2004 570 pilothouse shaft struts and stuffing boxes
Postby Viper » October 27th, 2025, 6:42 am
You can try Buck Algonquin for the stuffing box but there are others. Really any marine supply place can get these. They just need to know the OD of the thru-hull tube and the shaft OD. If they were traditional flax packing shaft logs, now's the time to consider dripless shaft logs.
A good propeller machine shop should be able to help with the struts. Check the existing ones for a part number stamped on it, that would help.
Check this link...
https://www.deepblueyachtsupply.com/collections/buck-algonquin
BTW, why do these have to be replaced?
Users browsing this forum: No registered users and 37 guests
