Westerbeke gas generator
- MyPleasure
- Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
- Has thanked: 2 times
- Been thanked: 23 times
I’m having some trouble with my 5kw Westerbeke gas generator. The engine itself seems fine, but when I try putting load on the generator, it dies. I’ve been trying to adjust the electronic governor, but now the speed adjustment doesn’t seem to be doing anything no matter which way I turn the screw. The generator only has 830 hours on it, but I’m thinking that I should replace the electronic governor.
Westerbeke has been awesome with advice, sent me a bunch of diagnostic tests, but nothing has helped so far.
Has anyone had any such problems with your Westebeke generators?
Thanks for any help as always
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
- Been thanked: 1312 times
Re: Westerbeke gas generator
As with any engine one of the first steps in diagnosis and tuning should be a compression test, visual check plugs etc.
Now if that screw is the idle fuel mixture and it is now too lean then for sure the engine will stall from lack of fuel when loaded. Perhaps the carb needs a cleaning, jets, emulsion tube etc. Even if it is something else that is a good regular maintenance item to complete.
Personally I would avoid adjusting the engine rpm/speed without being aware of the electrical output ( HZ spec ) that has to be met.
- MyPleasure
The newer model controller has 2 buttons to regulate the rpm up and down rather than a screw. I have a Westerbeke rep coming to see if he can diagnose what the problem might be, but I hate it when I can’t figure out what’s wrong. I know that the speed control screw on the electronic speed controller was working before, but now it doesn’t seem to speed up or slow down the engine. So I’m guessing that it’s that that is causing the problem. Only $650 cdn for a part the size of a deck of cards!
- kgarguilo
- Vessel Info: 1999 Carver 406
- Has thanked: 197 times
- Been thanked: 55 times
1999 Carver 406
- MyPleasure
I haven’t seen or read about oil for the governor. Funny thing is, the generator is running great! I had an appointment with the Westerbeke mechanic to come and look at the generator, but somehow the problem fixed itself over the winter. I’ve run it several times lately, and it’s working perfectly. Maybe it’s going to grenade this summer, but I’ll have to wait and see.
