Ontario Genny Specialist
- Washopay
- Vessel Info: 1990 3807 Aft twin 7.4 Mercruisers
1984 3207 twin 270 Crusdaers - Location: Barrie, ON
- Has thanked: 23 times
- Been thanked: 5 times
Can anyone recommend someone? I will remove it and deliver it if necessary.
Livinthedream
Re: Ontario Genny Specialist
- Washopay
Genny runs great. Then it stalls out after 20 mins. Then 15. Then 5. I changed high temp switch, oil pressure switch, fuel filter, checked filter basket, impeller. Before I brought in a crook from Orillia. "Yer mufflers too big." Huh? "Yeah. It's overheating. Water is not exiting the muffler." Yes it is, it drains into an exhaust box. Did you put a gun to it? I did and it is not overheating. "That's why I don't like working for boaters. You guys think you know everything". Ka-Ching. $400 and he left a chewed up piece of gum on the control box. On-line forum (Smokstak) advises a vapour lock maybe? Loosen the fuel filler cap on the tank she draws from by a thread or two. I did. Problem solved!
Went away on holiday, fired up the genny and the starter starts re-engaging periodically after she starts. Sounds like grinding coffee intermittently. My regular mechanic thought it was the starter and had it rebuilt. Same problem. I changed the solenoid. Same problem. i pulled the genny over the winter and gave it to my mechanic. He changed to control board $590 part. It ran great on his bench. I installed it 2 weeks ago, same problem. Suspected the remote starter was sending a signal (this was the only thing different from running on his bench). Disconnected then reconnected the leads. Then nothing. Nothing at all. Couldn't even get power to it. I suspected the starter relay switch in the control box. He says no. He spent 4hrs on it Friday. I still have no genny.
I can't spend much more on it. This is just killing me. Is this something you want to tackle? Want to come to Port Severn or do you want it in Sudbury?
- Washopay
- Washopay
Would like to look at the wiring diagram and see if there is a possibility of a feedback current once the unit is running that would make the start circuit engage. If this possibility exists, they'd take preventive measures like incorporating a diode into the circuit. In such a case, if the diode failed, it may be possible for a feedback. Just thinking out load, would have to check the schematic. There are a few other possibilities but it looks like you've addressed them.
- Washopay
- Washopay
Users browsing this forum: Google [Bot] and 13 guests
