Fuel valves on a '96 Aft Cabin
- williamnugent
- Vessel Info: '96 Aft Cabin 35'
- Has thanked: 2 times
Learning to drive this thing has been a challenge...
That said, I'm loving the entire experience.
One issue has come up regarding the fuel tanks on my boat. In the buying process, the fuel was turned off to both engines. I topped off both tanks and thought I'd repositioned the fuel valves so that the port engine would be taking fuel from the port tank and so forth for the starboard engine. Now after a couple trips, seems I'm feeding both engines off the starboard tank (starboard at 1/2, port full). Then there's the issue of the "aux" tank, which I know nothing about...
So, how do I set the fuel valves? Do I need to fill the aux tank separately?
What am I missing?
Thanks,
Bill Nugent
- Been thanked: 654 times
Re: Fuel valves on a '96 Aft Cabin
- williamnugent
I believe the fuel guages are working ( at least they were 2 weeks ago when I topped off). I also have 3 fueling ports, one starboard, one port and one aft ( port side of the swim platform) m. I had assumed the aft fueling port was a second access to the port tank to make fueling easier from one side. Apparently not . This must fill the aux tank.
Still not sure I've figured it out, but getting closer. So much to learn...
Bill
The two selector valves under the salon sole in front of the generator are for the engines only. If the piping was not altered, they should be pretty self explanatory. Each engine has port, starboard, aux and off setting set the pointer to the tank you wish to draw from.
