Fuel filter change
Re: Fuel filter change
You could change the housings and filters, but you will most likely continue to have the same issues until the BS in the tank is filtered out. You may want to consider just keeping several extra (cheap) filters on the boat and run the heck out of it.
When your RPM's are moving it's most likely not because of debris in the injectors, its because of low fuel flow due to clogged filters. The cheap filters clog at the surface rather quickly, the raco filters will capture at the surface and deeper into the filter giving a longer life, but for your problem, it may be cheaper to keep swapping the OE filters.
my 2 cents. best of luck to you.
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
- mjk1040
- Been thanked: 248 times
- cpoint
- mjk1040
- cpoint
mjk1040 wrote:Source of the post Cpoint, I would rather have to change a plugged filter than have to remove and have my injectors cleaned or replaced. I think 10 microns is standard, if not Viper will correct me. You'd be better off call Mercruiser the engine manufacture than Carver for that info. Mike
Thanks, I will call the engine manufacturer. I know what you mean about fuel injectors, in my case I had to replace them at $3k for injectors, + labor
- cpoint
- cpoint
Viper wrote:Source of the post Same filter. 35-802893Q is the old number and has been superseded to 35-802893Q01. You can also use 35-802893T which is the Mercury label instead of Quicksilver. The Merc is about $4 cheaper up here. These are the standard OEM filters for Merc inboards of that vintage. I'm pretty sure these are 25 micron and that it's the standard in gas apps.
Thanks, that's what I thought. I did see both online, they both say 25 micron. so if that's what the original was, which seems to be the case, I should stick with 25 micron. I assume 10 micron may cut flow down? I am guessing, I have no idea.
