Marine Air heat won't start
- 405driver
- Vessel Info: 1998 Carver 405 gas
- Has thanked: 37 times
- Been thanked: 6 times
I would think that the diagnostic is bypassing something while executing the test, but have no idea what?? Since it acts normal during the test it doesn't seem to be the reversing valve, and I would think that the unit itself is OK. Maybe a loose wire, circuit board (however no codes displayed) or the controller head.
Any ideas would be appreciated.
Re: Marine Air heat won't start
- 405driver
Do you know how the remove the control panel? I noticed a very small button on the bottom of the panel but not knowing what it is, I was afraid to push on it very hard.
- 405driver
This is a new boat for us, had it about two months. Lots of little things that needed to be fixed. The front heat has never worked. I talked with the previous owner last night and he even replaced the circuit board ($700) and it still didn't work. Late last night I went into the menu and found that U-1 was set on "cool only". I changed it to "automatic" and the heat came on . I hate to tell him that it might have been a menu setting all along. Hard to believe that a technician wouldn't have known that. We'll see what happens.
Thanks for your input.
PJHoffnet
- Has thanked: 55 times
- Been thanked: 18 times
- 405driver
The internet and this forum has been a great help in this "old boat" project.
Jump in, the waters fine.....the research is really quite fun.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 27 guests
