Installing Flooring in Carver Mariner
- amanphoto
- Has thanked: 3 times
- Been thanked: 12 times
Here are a couple of pics I found. I want to Salon and Galley to match, being that it's an open area.
- mjk1040
- Been thanked: 248 times
Re: Installing Flooring in Carver Mariner
mjk1040 wrote:Source of the post The possibilities are endless. Mike
++1
I think you'd be surprised at how much of what you see is vinyl. Some products look so real even I have to double check. The thing to remember about thin vinyl products is that they will show just about every surface imperfection of the floor you're laying them on, so make sure your substrate is clean and smooth with no pumps or cavities or they will eventually be noticeable. If the current floor is very uneven for some reason such as old glue, you can either remove with a sander or sometimes it's easier to lay a 1/4" sub floor over top. Use fillers to fill joints and low spots. Don't use solvents to remove old glue, the residue they leave behind may affect the new glue you use to apply your new product. The vinyls are typically glued down.
Wood products have been used for years with much success though they have their cons as well. One is that wood by it's very nature doesn't remain stable through varying conditions such as temperature, humidity, etc. Under some conditions, dimensions change, cracks can appear, finishes fade, etc. There is also a weight consideration. The only way I would go with wood is with an actual marine product like teak and holly. If I were in a climate where I wouldn't need to worry about climate, I may consider regular hardwood flooring but only if it were 1/4" thick. These are actually more expensive than the 3/4" variety (too much weight). Or I'd go with an engineered wood product. These tend to be more stable than solid wood. You can get this in teak and holly sheets. Pricier but the look is timeless.
Laminates are becoming more popular with DYIers such as in your second picture. Its cost makes it an attractive material to change an interior's look but keep in mind that if it's a traffic area getting wet at times, it may not be the best choice unless you're always on the ready to dry it up. Having said that, there are some waterproof ones, and some made of plastic. While these can float on the substrate, there will be areas that you'll have to mechanically fasten with glue or nails (hatches) depending on the material your substrate is made of.
If you're installing a product where carpet used to be, and the carpet wrapped around a hatch, you'll find quite a gap between the hatch top and surrounding floor to accommodate the thickness of the carpet. You'll need to fill this gap in somehow so that there is no cavity under your new flooring around openings.
Check out Google, boat shows, home shows, etc. Check out RV places too. They sometimes have product that doesn't always make it into the marine scene for a while. Pics from boats for sale are good for design ideas but it can be difficult to tell what product it actually is.
- feeez
- Has thanked: 52 times
- Been thanked: 66 times
Cheers
Fraser
http://www.powerboat-services.co.uk/?lightbox=dataItem-itd2hmq8
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
When were out in the San Juans, it gets bad with two kids, dog, crabbing and fishing.
After some research, I'll be using PlasTeak with a 3/16 floor cover padding with a Teak\Holly vinyl flooring.
I'm sure my boats floor is not even and it does have protruding screws, so I'll need a better base floor.
- SanJuanDreamer
TonyC
- Vessel Info: 1998 Carver 350 Mariner
- Has thanked: 22 times
- SanJuanDreamer
Mine is in front of the stairs/salon table.
Don't notice it until I'm standing in front of the table and someone walks by.
