Installing Flooring in Carver Mariner
Re: Installing Flooring in Carver Mariner
tom
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
tomschauer wrote:Source of the post Please let us know how you end up proceeding, and of course some good pics.
tom
Will do
never ending projects
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
Also, PlasTeak has color matching molding for the hatch edges...
- cpoint
- cpoint
tomschauer wrote:Source of the post Good start! I believe Armstrong S-750 adhesive can go over most other adhesives, even the nasty old black cut back, so long as the surface is smooth.
Thanks tom, will consider this. I may do some light sending. the existing glue is on fiberglass parts only lucky. Also after checking out the marine plywood for hatches, realized hard to find in my area, also pretty expensive, so I will re-use what I have by adding edges to them to compensate for carpet thickness that I have removed.
tomschauer wrote:Source of the post For the interior of the boat, I wouldn't be afraid to use good exterior sanded plywood for the subfloor.
+1
Non marine ply will do however it usually has fewer laminates so it tends not to be as stiff for the same thickness of marine ply. If you find after cutting it that there is more give than before when you walk on the piece, you can try encapsulating the cover with a couple of coats of epoxy. That should stiffen it up a bit without increasing the thickness much.
- Been thanked: 491 times
- cpoint
