1984 3207 Ignition Conversion
- paboater76
- Vessel Info: 84 3207 Aft Cabin
- Has thanked: 14 times
- Been thanked: 5 times
I have searched and search and read and read. Hall affect, HEI, photo eye etc. some I understand, some I dont. Most of the posts I have read are older. So I wanted to get a feel from the Carver community on the distributor conversion. Currently I have 2x crusader FWC 270's with original points etc.
My mech is recommending the Sierra 18-5296-2 kit. He is also going into the mechanical side of the dist and cleaning it up and replacing springs, weights etc.
I really would like to do the fully dist upgrade to this, but not sure it's worth if he can clean up my dist.
http://www.jegs.com/webapp/wcs/stores/servlet/m20ProductDisplayView?catalogId=10002&langId=-1&productId=231062&storeId=10001
Has anyone done the Sierra conversion kit, what are you experiences good, bad or indifferent? Do you wish you did the conversion or the upgrade?
Just trying to make an informed purchase.
Thanks,
Jason
- paboater76
Re: 1984 3207 Ignition Conversion
Also lots of carbon built up in the intake in front of Cyl 1/3
Compression on a stone cold winterized engine is 160 - 170 psi. on all cyl's
- Been thanked: 491 times
Or is he guessing?
If in fact the mechanical advance is sticking, I'd rebuild the distributors and use a Pertronix (sp?) pickup instead of points, using the stock advance system.
But if you do decide to try something completely different, make sure it is marine engine room rated.
- Has thanked: 603 times
My money for the cost would be new marine specific electronic.Perhaps that carbon at the end of your intake is only just timing related reversion........
- paboater76
waybomb wrote:Source of the post So is the tech saying the advance system is sticking and not advancing? On both engines?
Or is he guessing?
Thanks for the reply,
He is saying the advance is sticking just on the starboard engine, port is fine, he took the cap off and was twisting under the cap saying yeah they are sticky and possible broken spring. He has been a good friend and cert marine mech for over 30years at a well known marina, I would hand him my credit card and give him free reign, so I do trust him lol. He has a trojan 11m with identical engine and he will be doing the same to his engines once he does mine. whatever I order, I'm ordering 4 of, 2 will be his and payment for his services on my boat.
So you say go the conversion route using the sierra kit that is stamped Pertronix
- paboater76
This would be the upgrade kit by sierra that has the Pertronix.
Springs are cheap if broken and rust is easy to clean up.
Make sure he checks the spring posts for wear and replace the parts of worn.
I'm a big fan of using as much oem as possible. In fact I use stock TBIV ignition on my 3 572s in Plain Vanilla. Only thing I changed was the modules and used V6-14 so I can dial in more initial advance for easier starting.
paboater76 wrote:Source of the postwaybomb wrote:Source of the post So is the tech saying the advance system is sticking and not advancing? On both engines?
Or is he guessing?
You are very lucky to have someone like that , who you can trust, sounds like it will work out fine......
You can't assume much about the carbon until you get a proper working distributor installed. You may also want to take a compression test under closer working conditions like getting the engine hot and retesting. I'd also hook up a vacuum gage, it can tell you a lot if you know how to read it. Are you burning any oil?
