My Launch Is Delayed
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
I arrived back at the boat. I then decided it would be a good idea to turn the engines over. I turned the key for the starboard engine and it cranked over as it should have. I then turned the key for the port engine and nothing, nada, zip, zilch. Nothing happened.
I took a quick check below in the engine compartment but I could not see anything out of the ordinary. Now, it was my port transmission that had been rebuilt and they had to pull the engine so they could remove the transmission to effect the rebuild.
I am thinking that when they reinstalled the engine and transmission something was not reconnected. I am hoping that it is something that simple. I can't think of anything else it could be. Both engines turned over in December and January when I went to check on them so it is only after the engine removal that it will not start.
A friend of mine suggested that I wiggle the shifter at the helm with the key turned on to the start position to make sure the neutral switch is working. I did that turning the key into the start position while moving the shift lever all the way forward and aft. Nothing happened.
Both batteries are fine so it's not the batteries. So, everyone please keep your fingers crossed that they will find and solve the problem. I am looking forward to hitting the water and getting my dock set up at my new marina.
Obviously any ideas or suggestions from members here are greatly appreciated. I will head back to the boat on Saturday.
Hoping to launch soon.
- Ramsport47
- Been thanked: 59 times
Re: My Launch Is Delayed
T-Merc 350 Mag MPI (300hp)
Hopefully something simple!
- feeez
- Has thanked: 52 times
- Been thanked: 66 times
Cheers
Fraser
- RGrew176
Thanks for all the tips.
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
..Aaron
SeaDragon
- RGrew176
AaHubb wrote:Source of the post My engines have separate battery disconnect switches, maybe yours do too.
..Aaron
Anything is possible. I will have a chance to get back to the boat next Wednesday. I will try to squeeze myself down into the engine compartment and take a look.
- RGrew176
I am glad that it was a simple problem and not a new issue. My feelings that it was related to the transmission rebuild look to be the correct assumption on my part. I will be headed to the marina today (Thursday) to make an appointment to launch. I am going to try for a Saturday afternoon launch. Hope they can get me in the water at that time.
- mjk1040
- Been thanked: 248 times
- RGrew176
mjk1040 wrote:Source of the post Good Luck Rick, our lake level here is so high it may be the 1st of May before we launch!
Thanks. I have a Saturday 3:30 PM appointment to launch. Barring any more complications let the season begin.
