paint on radar arch of 4207
tc'sbackporch
Vessel Info: 1987 carver 4207
Has thanked: 6 times
Postby tc'sbackporch » May 30th, 2017, 11:12 am
we have some paint flaking off the radar arch. has anyone ever bought any paint for theirs and if son what color.
Been thanked: 490 times
Re: paint on radar arch of 4207
Postby waybomb » May 30th, 2017, 9:29 pm
Give Carver a call in Pulaski.
SplashyLady
Has thanked: 20 times
Been thanked: 88 times
Postby SplashyLady » May 31st, 2017, 11:05 am
Interlux Brightside Poly - color 4381 Off-White is a very close match to the Carver gelcoat/hull. The newest version of this applies nicely with a roller, levels well, and gives a satisfying gloss. You can do roll and tip with a brush if you want, but I've gotten pretty nice results with just a fine nap roller. You can also shoot it through most airless sprayers without thinning.
http://www.yachtpaint.com/usa/diy/produ ... thane.aspx
Captain John
Lake Norman, NC
Carver 3227 - "Splashy Lady"
pikaman
Vessel Info: Carver 390, 1993, CPMY, twin crusaders, full awning model.
Been thanked: 6 times
Postby pikaman » May 31st, 2017, 11:40 pm
hello TC
I have the same problem on our 390. What we did was take one of the inspection plates off as there are at least two, and took it in to have a computer colour match done at the local paint shop. We ended up with almost a dead match, very happy, and used a single component polyurethane semi gloss that we used with a foam roller and brush on the aft deck columns and the arches.
I contemplated spraying, but it takes a lot of prep-work and protection, so doing it this way you end up with a decent job that no one can tell at one pace away.
garytheguard
Vessel Info: 1989 Carver 3807
Has thanked: 3 times
Been thanked: 2 times
Postby garytheguard » July 15th, 2017, 5:06 am
What type and brand of paint did you use?
Gary Trevisan
1989 Carver 3807
Thunder Bay, ON, Canada
