1999 350 Rear cockpit door cushion pad
ChiefDaveD
Vessel Info: 1999 350 Mariner
Postby ChiefDaveD » June 4th, 2017, 5:05 pm
Does anyone know how to remove the cushion pad from the top of the rear cockpit door that leads to the swim platform? I cannot figure it out. Took the door off the hinges and looked up through the cavity and there are no screws or anchors visible. We got all the other 4 off with no problems but cannot get the one on the door off. Any advise or recommendations would be welcome.
Dave Dunham
1999 350 Mariner
Re: 1999 350 Rear cockpit door cushion pad
Postby bud37 » June 4th, 2017, 5:17 pm
Welcome to the forum........I think if you do a forum search, recently I remember ramsport answering that same question....I believe he said it was glued down but please don't quote me ( brain is a little old )....check it out.....good luck with your boat...... :beergood:
Agriman
Vessel Info: 1998 Carver 350 Mariner Twin 454 Crusaders
Has thanked: 5 times
Been thanked: 5 times
Postby Agriman » June 5th, 2017, 10:15 am
I removed mine a couple years ago, but do not remember exactly how. I know I did not remove the door and it was not glued down. I believe there was a couple of plastic strips on the inside that was screwed to the door, but I would have to look this weekend to be sure.
Agriman
Postby Agriman » June 5th, 2017, 10:24 am
Check out the forum under :The Project Center attention 350 Mariner owners for ideas. It seems others were glued but mine came loose easily after taking out the two screws.
Postby bud37 » June 5th, 2017, 5:58 pm
The two screws everyone is referring to are on the cockpit side face of the door just below the edge of the pad.....just came back from boat.... :beergood:
ChiefDaveD
Postby ChiefDaveD » June 5th, 2017, 6:01 pm
Thanks for the timely replies. I didn't see any screws around the edge of pad but I'll take a closer look next trip to the boat.
Been thanked: 491 times
Postby waybomb » June 5th, 2017, 6:24 pm
Does the pad have a zipper on it? Maybe pull the foam out and there are screws inside?
ChiefDaveD
Postby ChiefDaveD » July 22nd, 2017, 7:53 am
No zipper and still haven't figured it out. No screws as mentioned above. We want to have them re-covered but still cannot figure it out. Has to be a way but cannot figure it out. Might have to call CV and ask them perhaps.
Dave
