Carver 530 Voyager
Topic author
enproep
Vessel Info: 2000 Carver 530 Voyager
Carver 530 Voyager
Postby enproep » June 27th, 2017, 12:50 pm
Hello, I have twin diesel's in my 530 Voyager that are 17 years old with only 950 hours on them. They run great, but I've recently noticed seawater dripping at the end cap of the port heat exchanger (1 drop every 5 to 10 seconds). My mechanic is recommending I replace both heat exchangers as well as service the aftercoolers and transmission coolers. My question is, does anyone have experience/comments on this? Can the leak be patched with JB Weld? What are the ramifications of letting it go for awhile. Heat exchangers, aftercoolers and transmissions were serviced 5 years ago (approx. 300 hrs ago). Thank you in advance for help/advice. Bob
Been thanked: 248 times
Re: Carver 530 Voyager
Postby mjk1040 » June 27th, 2017, 6:27 pm
Well u could exchange them out or take it out to have repaired, if there is enough material to work with for a good repair. Then again it could just need to be re-soldered? I would think any good radiator shop would give you a good idea which way you should go! Try some flex seal tape on it!
mjmason1
Vessel Info: 1999 Carver Voyager 530
Has thanked: 2 times
Been thanked: 19 times
Postby mjmason1 » June 27th, 2017, 7:40 pm
It's possible you just need to reseal the end cap. I would try that first. Taking the heat exchangers off and having them serviced is fairly inexpensive.
Postby Viper » June 27th, 2017, 8:44 pm
It would help if we knew what power plants we're dealing with. Volvo TAMD? Which one?
Topic author
enproep
Postby enproep » June 27th, 2017, 8:50 pm
Viper wrote:It would help if we knew what power plants we're dealing with. Volvo TAMD? Which one?
Sorry, my bad. They are Cummins C series, 8.1 L 450 HP.
They look pretty straight forward to remove, anyone know if that's the case?
rcoff512
Vessel Info: 1999 Carver Voyager 450
Home Port, Long Island NY USA
Has thanked: 12 times
Been thanked: 8 times
Postby rcoff512 » June 30th, 2017, 9:06 am
ENPREOP
If it is the end cap on your "heat exchanger" they are available as replacements,
http://www.mrcool.us/end-cap-4-inch.html
If it is the "after cooler" these won't help, but after cooler parts are available also.
https://www.sbmar.com/product/cummins-a ... es-engine/
Rich
Karen Powell
Vessel Info: 2001 model Carver 396 Motor Yacht
Has thanked: 13 times
Postby Karen Powell » August 28th, 2017, 1:15 am
I think it's better to get it replaced.
Australia
Golfgippsland
Vessel Info: 1989 Santego 2767 mid cabin express
Been thanked: 2 times
Postby Golfgippsland » August 29th, 2017, 3:26 am
I also had a slow leak on one of my heat exchangers
A new end cap fixed the problem $40. Got to be worth a try before pulling the exchanger.
Gippsland lakes Australia
1989 Carver 2767 Santego
1971 v156 glastron modified
1985 whittley cruisemaster
1982 2950 Bayliner offshore express
