FM Antenna location and type?
amanphoto
Has thanked: 3 times
Been thanked: 12 times
Postby amanphoto » June 26th, 2017, 9:07 am
Just a quick question. Where is the FM antenna from the radio mounted in the salon? What kind of antenna is it?
Re: FM Antenna location and type?
Postby bud37 » June 26th, 2017, 9:22 am
The one in ours appears to be original and is just one of those antennae wires, and is hanging behind the entertainment centre ...I couldn't find anything else....... :beergood:
Been thanked: 470 times
Postby RGrew176 » June 27th, 2017, 4:28 am
That is what most boats seem to have for a radio AM/FM antenna. I have only seen a few boats that have an actual antenna.
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Postby AaHubb » June 28th, 2017, 10:55 am
Mine has a 3ft whip mounted on the port side of the fly bridge. I assumed it is a factory install but don't know for sure.
..Aaron
'99 404 CPMY
SeaDragon
Been thanked: 491 times
Postby waybomb » June 28th, 2017, 12:24 pm
I have an 8' Shakespeare fm antenna on the other side of the arch from the vhf antenna. If for no other reason, to keep the vessel symmetrical in appearance
amanphoto
Postby amanphoto » June 28th, 2017, 9:20 pm
Has anyone had luck putting a VHF antenna splitter in? Does is degrade the VHF performance?
https://www.westmarine.com/buy/shakespe ... ecordNum=1
Postby tomschauer » June 28th, 2017, 11:00 pm
I also have a 3' fm antenna on the port side of the bridge, seems to be factory as the wire is bundled with the rest.
I used an identical band splitter on a previous boat. I didn't notice any change in VHF performance, however, if I had the vhf and the radio on, I would often hear the vhf through the radio speakers. It seemed this only happened with a strong local vhf signal.
SplashyLady
Has thanked: 20 times
Been thanked: 88 times
Postby SplashyLady » June 30th, 2017, 11:59 am
amanphoto wrote:Source of the post Has anyone had luck putting a VHF antenna splitter in? Does is degrade the VHF performance?
I don't recommend a splitter - seem to impact performance both ways. If you are in a very remote area, consider a small amplified antenna mounted somewhere in the cabin (even behind a panel is OK). Terk makes a good one and one I currently have uses a 12vDC power supply:
http://www.ebay.com/itm/Terk-Tower-Indo ... SwDNdVpp2p
Captain John
Lake Norman, NC
Carver 3227 - "Splashy Lady"
Lyndon670
Vessel Info: 2000 Carver 506
Volvo TAMD74EDC
Has thanked: 124 times
Been thanked: 140 times
Postby Lyndon670 » July 6th, 2017, 11:21 pm
I had the splitter on my Silverton 42C, and had no problems. I am about to order one for my 506.
Lyndon,
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
Postby tomschauer » July 26th, 2017, 10:43 pm
Lyndon, did you order your splitter?
If not let me know, while cleaning the garage I found a shakespeare 4357s splitter. Brand new never used. I am bit AR and usually buy two of everything.
If interested you can have it for $30.00 plus shipping at cost, probably about $6.
Let me know
Tom
