Water leak around dripless bearing
- crquisto
- Vessel Info: 2000 Carver 406 Aft Cabin, twin 7.4 gas Mercruisers - Flyboy II
- Has thanked: 2 times
- Been thanked: 3 times
Re: Water leak around dripless bearing
- crquisto
- crquisto
I can't quite tell if this is a face seal or lip seal but face seal units have a bellows type hose as they must be pre-loaded so that there is constant pressure between the carbon ring and the stainless collar. That makes a difference if you want to reduce that gap. It looks like a Tides Marine lip seal type log. If it's a Tides Marine lip seal unit, you can loosen the clamps and push the seal assembly back.
The stainless collar at the front, does it have a couple of set screws in the side?
- crquisto
I think you are right that it is a Tides unit. I have all the original parts list and in the propulsion section, right after the two 1-1/2" shafts it shows two "SHFTLG: 1-1/2 X 2-1/2TIDES". Looking at the starboard side, there is no gap between the blue sleeve and the black shoulder, so I guess the port side should be the same. I didn't have a lot of time today but I did try to loosen the clamps a bit and slide/stretch the sleeve to close the gap. No luck. Maybe have to loosen the clamps some more? It just looks like the sleeve is too short to push up tight in a "lip seal".
The sleeve is pliable and I can feel the water in it and the hard shaft log underneath it. When I squeeze, water leakage increases - definitely squeezing out in the 1/4 inch gap forward of the blue sleeve. I tightened the clamps and yesterday I closed the port engine cooling thru-hull. That has cut leakage off, so I guess the water was coming thru the cooling system and not directly thru the bearing seal. Any further inputs appreciated. Would it just be sensible to replace the shaft log, and could that be done in port?
- Has thanked: 603 times
- crquisto
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
..Aaron
SeaDragon
- crquisto
