Trouble with Packings
- Bankerbiz87
- Vessel Info: 1982 Carver Mariner twin 220 engines 28ft
- Has thanked: 10 times
Re: Trouble with Packings
There should be a drip every 5-6 seconds when running if they are adjusted right. (that's for prop shafts, the rudder shafts should not leak at all)
What screws are you talking about? There are usually just two big nuts.. the packing one and the locking one.
https://www.deepblueyachtsupply.com/00sls125g-shaft-logs-square-base-complete-assembly
- mjk1040
- Been thanked: 248 times
Viper wrote:Source of the post There is a type that uses two bolts:
Interesting! I've never seen one of those before. Is there any advantage to something like that?
To the OP's question about whether to replace the bolts with plastic..... IMO, NO! I would not want a plastic bolt holding something like that in place. Those look like bronze bolts, so I would not think that corrosion would be an issue.
No, I would not use a plastic bolt. A picture would really help. After replacing packing and the initial tightening (not too much), you must take the vessel out for a run and allow the packing to take shape with the shaft spinning, then inspect the drip and re-tighten accordingly (not too much!) as it's likely it will leak more after the first run. You may have to do this after the first couple of runs. If the packing material is old, it won't matter how much you tighten it, it will likely never stop leaking and should be replaced. Don't tighten the packing too much at once or you'll overheat the log and shaft possibly damaging both. A drip every few minutes is normal, and more often when under way. Water lubricates, if you prevent it from leaking completely, you will have a failure eventually.
- Has thanked: 602 times
