Electrical Voyager 530
Captain Dan
Topic author - Scurvy Dog
- Vessel Info: 54' Carver Voyager, 2000.
My Voyager recently caught fire at the shore plug inlet. Fortunately the fire was put out quickly and repairable. There was a wiring harness in the upper area Port side running along past the fuel tank into that corner. It was burned pretty badly and I don't know what it did. A lot of wires were loomed low around the exhaust and it is okay, the fire went up. I think those operate the autopilot, rudder position sensor etc. The upper harness had a small relay in it also that was completely melted. If you know what that harness does please let me know. The mass appears to contain around six or seven wires.
Thanks. Captain Dan
Re: Electrical Voyager 530
Is there any wiring in good enough condition that could be followed to a piece of hardware, switch, or breaker? A detailed visual inspection may reveal something beneficial. There has to be a place along the bundle where the wiring didn't burn. That would be a good starting point. Accessibility will make or break how easy this project will be.
Until things get figured out, I don't think I'd be turning anything on for fear that you start another electrical fire as I'm sure you now have shorted circuits.
Captain Dan
Thanks for getting back to me and the good advice. I am working with Carver on it and they have been very helpful. The fire stopped at the bulkhead and the wires are good forward of that area. The problem is that whole back corner was consumed and the wires were just a mass of melted components and bare copper. I found the remnants of one relay but not much identifiable. Some had to be ground wires and a few were to lights but the rest are a bit of a mystery. I sure don't want to start turning things on to find out what doesn't work.
Fair seas and tail winds.
Dan
It's a tough one. Without a schematic of the circuits and how/where they run throughout the vessel so you can isolate the circuits in that bundle, the only option is to chase the affected wiring and see where they go. Not always the easiest thing to do but you may not have a choice in this case.
Perhaps someone can offer up a different approach.
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
