32 Carver aft cabin Carburetors
- MakinTime
- Vessel Info: Carver 3607 MakinTIme
Glastron MX175 MakinTimeToo - Has thanked: 52 times
- Been thanked: 31 times
- MakinTime
Re: 32 Carver aft cabin Carburetors
- Has thanked: 603 times
- Been thanked: 491 times
What's the concern?
- mjk1040
- Been thanked: 248 times
- MakinTime
Get a couple $20 rebuild kits and replace the bow gaskets and the float level gaskets. Set the fuel level correctly in the bowls and you should be good to go.
If you replace all the gaskets and set the levels correctly so they are not dumping fuel into the manifold, your smell should go away.
I would also check the fuel pump feed to the carb to make sure you're not seeing any fuel there... that's an indication of a pump diaphram failure.
If you're seeing gas at the top of the carb, it's probably either a mis-adjusted float, a bad float, or a dirty needle/seat. Very easy items to troubleshoot and fix.
Did it smell like gas before he bought the boat, when he first viewed it?
Have you checked the fuel fill hoses to the tanks and the tank vent hoses for cracks?
Have you checked the base of the tanks for signs of leaks?
What year is the boat?
Were the tanks pressure tested?
Did he get a survey?
- MakinTime
Users browsing this forum: geo and 13 guests
