Fuel Fill Hose Cracking
- kdaniel3
- Has thanked: 4 times
- Been thanked: 2 times
This was out of a recently acquired 2004 Carver 396MY and the hose had a 2003 manufacture date, see attached pics.
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
Re: Fuel Fill Hose Cracking
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- Has thanked: 603 times
dsolo wrote:Is the hose condition related to over filling the tank? Or fuel tank vent lines being plugged? Trying to understand how a hose rated to withstand fuel contact can degrade?
Just the nature of rubber hose...I bet you could take a new piece of that hose and put it in your living room and in 15 years it will have dried out.Now engine compartment ,hot cold cycles and fuel vapour , well you get the idea.I believe the rating would be for a set period of time to handle fuel. I have pulled that stuff out of a couple boats and it is always degraded more than it looks on the outside..... :beer good:
I have some left over( still in plastic ) from last boat and will replace the hose an this boat when I can get my old body down there..
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
At minimum, you should get a quality Type A-2 marine fuel hose which is rated for diesel and E15 gasoline. Don't forget to replace the vent hose as well, and make sure it is looped upward from the hull vent before it heads to your tank. From the hull vent fitting to the tank should be down hill only with no sags in the hose where fuel would sit in an over-fill condition and prevent venting. Use stainless steel clamps only. Premium clamp designs help seal better than the typical hose clamps. Double clamping while not a requirement, also contributes to a tighter/better seal as you won't find out if the connections are secure enough to prevent leaks until you're over-filled one day. A poor seal may leak during the fill process so check for leaks at your first fill after the install, and use your nose to help.
The supply lines to the engines will have a hard inner liner and you should avoid using a heat gun to help with installation as that might distort and tear the liner at the connection which would de-rate the hose. I've also seen the liner get heated up enough that it separates from the outer cover and gets pushed into the hose during installation causing a restriction.
