What Oil To Use in My Genny Kohler 7.3
Re: What Oil To Use in My Genny Kohler 7.3
Postby tomschauer » September 6th, 2017, 10:52 pm
you will find many opinions here. I personally use Mobile 1 10/40 in my genny. As long as you use a quality oil and change it regularly you shouldn't have a problem.
Best wishes.
Been thanked: 248 times
Postby mjk1040 » September 7th, 2017, 5:47 am
Rotella 10W30 Here!
Postby bud37 » September 7th, 2017, 8:22 am
Same genny...for me it will get the same as the engines...Rotella 15w40 and I agree, any good quality oil in the right grade range won't steer you far wrong....
feeez
Vessel Info: 2001 350 Mariner
Has thanked: 52 times
Been thanked: 66 times
Postby feeez » September 7th, 2017, 10:43 am
+1 on the Rotella 10w30 or 15w40
Former 2001 350 Mariner owner
Postby bud37 » September 7th, 2017, 12:50 pm
Lots of discussions/opinions about filter choices nowadays....anyway Wix/napa gold for me....a little more but I trust them.... :beergood:
Postby Midnightsun » September 7th, 2017, 2:00 pm
15w 40 Rotella. Been using this in my previous inboards and the generator and still using the same in my diesel setup.
Postby Midnightsun » September 7th, 2017, 3:06 pm
nautiyachti wrote:Source of the post bud37 I hear ya...I wouldn't want to start a whats the best oil or oil filter thread...but I just curious mostly to hear if anyone has had a bad experience using the readily available less expensive alternative stuff. I don't put many hours on my boat (under 50 for sure) and would change oil seasonally so i'm not sure oem premium stuff is worth it.
I have used many different brands over the year including the poor Fram which has an undeserved bad reputation from long ago. Never an issue.
Postby tomschauer » September 7th, 2017, 4:01 pm
if you have remote oil filters that are inverted, make certain the filter you buy (no matter what brand) has an anti drain back valve or you get a second or two of dry run every time you fire it up.
Postby km1125 » September 8th, 2017, 7:54 am
Midnightsun wrote:Source of the post
I would not say that Fram's reputation was undeserved! When I saw the teardowns of the various filters, I was HORRIFIED to see the cardboard failures inside the Frams, as that it what I had been using for years. I have not used them since and have not seen any other teardowns to see if they've made improvements or not.
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Postby tonyiiiafl » September 10th, 2017, 5:48 pm
Mercruiser 25W40 in engines and genny
Return to “Electrical”
Users browsing this forum: Google Adsense [Bot] and 18 guests
