Cant shift gear for starboard side
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: Cant shift gear for starboard side
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
- cpoint
Viper wrote:Source of the post Yes likely tranny issue. There does seem to be corrosion so I assume they checked to ensure corrosion isn't preventing the lever from moving? Can the shaft be turned by hand?
Viper once again you were right
Luckily, it turns out was not the transmission. The transmission coolant unit apparently had a hole and was leaking, caused the lever to have corrosion. apparently also made the starter wet, which dried now. Seems to be working fine, but was told if it goes in a year or two not to be surprised.- nightsky
- Vessel Info: '94 Carver 390 cpmy
- Has thanked: 6 times
- Been thanked: 16 times
- cpoint
- cpoint
