366 Kohler Generator raw water discharge?
- hargsnz
- Vessel Info: 366, 2003, twin Cummins 280HP, Kohler 8.0,
- Has thanked: 4 times
- Been thanked: 4 times
It's true to say I haven't paid much attention to where the raw water from the generator exits the boat until now.
I replaced the impeller & took the heat exchanger off & cleaned it up, flushed & replaced the coolant & started it up. The first thing I looked for was to see the raw water discharge.
There was none I could see. None coming out of the exhaust outlet at the stern of the boat.
Expecting a blockage between the siphon break & the muffler, I've spent some time cleaning out the hoses etc with Barnacle Buster type stuff. If I now blow through the hose at the siphon break I can hear bubbles in the muffler.
But still no water out of the exhaust outlet.
However I do see the water coming out underneath the boat part-way down the hull. The generator runs OK but surely it's not meant to be in effect a dry exhaust going the length of the boat?
Because the generator is under the floor & up against a bulkhead I can't see the elbow mixer for the exhaust & the raw water, without cutting some extra hatches in floor.
Can anyone help with information for this model 366 exactly where the raw water is supposed to come out from the generator?
- Has thanked: 603 times
Re: 366 Kohler Generator raw water discharge?
http://www.carveryachts.com/media/3993/2004-3408v1.pdf
http://www.carveryachts.com/media/3829/ ... ual_03.pdf
http://www.centekindustries.com/products/2-x-2-x-1-5-gen-sep/
You may have a canister style but one hose will lead to a seacock.
- hargsnz
I do have a canister muffler & it has water in it as a 'water-lock' style. I'm told there's an elbow behind the generator that I can't see that's supposed to combine the gases & the salt water. I just can't work out why they'd separate the water back out.
I was hoping another 366 owner would step in an advise where the salt water comes out on their boat.
I guess I'll just cut the hatch in the floor over that side & take a look. I'm concerned that this elbow ( like a riser ) may have collapsed internally some way blocking the water flow & the underwater exhaust. It looks to me that the water should come out at the stern & the exhaust exit under the boat. That is an "underwater exhaust' like it says in the marketing material.
If you have a separator, it will either be built into the muffler or a separate unit from the muffler. if you see a smaller hose coming out of your muffler along with the exhaust hose going into it form the generator and out again to the stern, then you have a built in separator. If you don't see the smaller third hose, follow the outlet exhaust hose from your muffler and see if it leads to a separator as noted in my link above. If it doesn't, then you should be getting water out the side of the hull where the gases are discharged.
If you're not pumping water, the generator won't run for long if its over-temp shutdown is working properly. Don't know what model you have but it may also have a low water pressure shutdown if it's not pumping. If it does have low pressure shutdown feature, the generator won't run longer than 10 seconds when there's no water.
- hargsnz
