Documented boat
- darylann
- Vessel Info: 1992 Carver 33 Aft Cabin... My first boat!
Dreamed and schemed for 7 years, and finally made it happen in 2017! - Location: Peoria, IL
- Has thanked: 78 times
Documented boat
So what do I do with this information? Is there a protocol I need to follow or be aware of? Should I find out if the change of title and boat name was ever recorded from the first to the second owner? Do I notify the USCG as the new owner?
The surveyor seemed to shrug it off when I mentioned it to him, as if it wasn't important and was totally up to me if I wanted to spend the money for the documentation or not. What exactly are the benefits of being documented, and would it be to my benefit to follow up on this?
Any suggestions, answers or advice welcomed!
Peoria, IL (for now)
My first boat!- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Documented boat
You can look up your boat on the CG website to see if the documentation is still valid. If it is, it will be easier to transfer over to you. If not, a little more trouble, but again, your choice.
I like being documented strictly for the snob factor of not having state numbers plastered on the bow and in VA, documented boats do not have to be state documented. It's optional.
Another question, if you have state numbers on the bow, then your boat is not documented. Documented boats cannot have state numbers even though most are registered with the state sticker somewhere on the front end of the boat.
- Been thanked: 491 times
Re: Documented boat
Re: Documented boat
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
Re: Documented boat
I am the second owner and what I found out it that the document number stays with that vessel for the life of the boat. When I purchased my boat this spring the broker wanted $995.00 to transfer the document! I declined and told them that I will take care of that myself. It cost me $100.00 and filing a few forms.
I would recommend that you call the USCG Vessel Documentation Center. They were excellent.
Every time I called, I got through. The folks were very helpful and in one instance even returned a call.
Here is their link:
http://www.dco.uscg.mil/Our-Organizatio ... on-Center/
Lots of luck with your new boat.
- buster53
Re: Documented boat
- darylann
Re: Documented boat
buster53 wrote:Source of the post ...
There are state numbers on the bow. But the boat also had been documented. According to the Illinois DMV website: "A watercraft which has a valid marine document issued by the United States Coast Guard, National Vessel Documentation Center, is required to be registered (not titled) in Illinois if used upon the waters of this State for more than 60 days in any calendar year." I'm still not sure if this means that the numbers MUST be displayed or not; I've heard conflicting answers to that question.
My first boat!- g36
- Been thanked: 654 times
Re: Documented boat
- Has thanked: 603 times
Re: Documented boat
darylann wrote:Source of the postbuster53 wrote:Source of the post ...
I wonder what they mean when they say "used upon the waters".....could that be in the state ,on blocks on the hard or only apply to floating.I don't blame you for having some confusion in the matter.......
Re: Documented boat
Users browsing this forum: Google [Bot] and 14 guests
