Inflatable boat
- MakinTime
- Vessel Info: Carver 3607 MakinTIme
Glastron MX175 MakinTimeToo - Has thanked: 52 times
- Been thanked: 31 times
Inflatable boat
Re: Inflatable boat
Re: Inflatable boat
If you're talking 4 stroke, then the merc 4, 5 and 6 HP engines are all identical with the exception of the carb (tohatsu is the same, as they are the manufacturer for merc motors). They all weight exactly the same. I upgraded mine to a 6hp carb and added a high-thrust prop. On normal conditions, that will get us (2 people, dog and cooler) up on plane and make for a quick trip to the shallow areas 3 miles away. With heavy seas, that extra 50% power makes it easier to handle too. It is a lot of fun. I don't even have davits for it, I just tip it up on the swim platform and tie it securely
- Has thanked: 603 times
Re: Inflatable boat
KM what do you mean by a high thrust prop....might be something I could use.
Re: Inflatable boat
Re: Inflatable boat
Re: Inflatable boat
For the Merc/Tohatsu/Nissan 4, 5 and 6 HP motors they make a prop nicknamed "Mouse Ears". It is a low-pitch, high thrust prop that is used on the Sail-Pro motors. The 5 or 6" pitch allows the motor to get up to it's rated RPM and the big blades throw a lot of water. You might lose a couple mph (or kph) at top end on a lightly loaded dingy, but it will allow you to actually get on plane when you have a fuller compliment on the boat. It still won't plane something with 3 or 4 folks though. Mine will cruise at 13-14 MPH on plane with our normal load and a little over 15 with light load. With the original prop, I could get on plane with a very light load, but it would take some work - maybe surfing someone's wake or catching a wave just right. Now it's not a problem unless the seas are heavy (but you'd probably get beat to heck if you did get on plane anyways)
I was told for years I would never get on plane unless I upgraded to a 8 or 9.9HP.. but those are a LOT heavier to haul around. This solution has worked very well for us.
Re: Inflatable boat
Viper wrote:Source of the post Bud37, if the dinghy is out in the sun, do you find that the aluminum floor gets really hot? Current dinghy is wood floor but we're getting another one next season. We spend a lot of time on the hook so the dinghy floor would probably catch the sun most of the day. I like the aluminum floor but because it may get too hot, I'm on the fence between composite and aluminum. What have you experienced?
My original wood floor was dark brown wood, and it would get uncomfortably hot if it was sitting in the sun. It would also get slippery when wet. For quite a while I considered just getting a piece of marine carpet and snapping it in there...thought it woulnd't add much weight but would be very comfortable and address both issues. A few months ago I added some non-skid strips of tape (3" wide) and then painted all the boards with some light grey garage floor epoxy. This has helped tremendously on both counts and also looks much nicer. The only thing I forgot to do was wipe down the top of the non-skid strips with acetone or thinner to clean then and I have a couple spots where the epoxy is flaking off on them after some heavy use this summer.
Re: Inflatable boat
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: Inflatable boat
Each type has it advantages and disadvantages.
Users browsing this forum: No registered users and 5 guests
