Engine Harness Schematic
- dcrahn
- Vessel Info: 1984 Carver 2687 Monterey
- Been thanked: 4 times
Re: Engine Harness Schematic
Why are you looking for a schematic, do you have a wiring problem you're trying to diagnose?
- dcrahn
- Has thanked: 603 times
dcrahn wrote:Source of the post The engine is a 1986 Volvo Penta 5.7 (GM350). No problems, but I do have a couple of wires that are no connected to anything and I would like to run the engine before I install it in the boat. I'm trying to avoid cutting the wire loom wrapping to trace them out to where they go.
Could you just go thru the harness with a multimeter to check continuity, that should id wires for you, if I follow what you are asking correctly........Happy Christmas.....
- dcrahn
I would verify you have oil pressure, temp gauge and neutral safety switch connected. Make sure the unused wires are insulated and fire it up.
Also, something that many people seem to disconnect rather than fix the problem is the shift detent switch. If not set up correctly it will make your engine stall when shifting in and out of gear.
- dcrahn
- dcrahn
Viper wrote:Source of the post I suspect the connector isn't original for that vintage. What colour is the wire? If it's original, it may lead you to the appropriate circuit.
I don't think it's original either. There are no Weatherpack connectors anywhere else on the boat plus I don't remember seeing them used on boats of the 80's era. The wire color is Green.
