What is this and where does it go?
amanphoto
Has thanked: 3 times
Been thanked: 12 times
Postby amanphoto » December 26th, 2017, 5:00 pm
I have this mystery hose in my bilge of my 1999 Carver Mariner 350. I'm not sure where it goes or what it does. The house is laying next to my hot water heater in the salon. It runs down with the other hoses toward the back of the boat.
Note: My hot water heater works great. The hoses from the port engine that supply engine heat are connected and working. Its to small to thread into the pressure relief valve. My drain on the hot water tank is female also so this could not thread into that.
Before I start taking things apart, I was wondering if you all had an idea.
Re: What is this and where does it go?
Postby bud37 » December 26th, 2017, 5:28 pm
Maybe from a previous heater or repair.....the relief valve looks like it is open???... the drain pipe gone seems to be missing ...... :beergood:
Postby Viper » December 26th, 2017, 11:07 pm
Perhaps the relief valve was changed with a different unit. There should be a hose from the valve leading to the bilge. If it discharges, that's where you want to direct the water rather than splashing it all over the place.
daveS
Vessel Info: ☀️Sanity Sol☀️
1999 350 Mariner
Has thanked: 24 times
Been thanked: 8 times
Postby daveS » December 26th, 2017, 11:26 pm
Chase the hose and see where it ends.
Looks like release valve hose
amanphoto
Postby amanphoto » December 27th, 2017, 7:54 am
Yes the relief valve is open. I opened it to drain the water tank for winter.
I was under the impression that nothing should be connected to the relief valve. It could cause a restriction and course the unit to blow up.
Postby Midnightsun » December 27th, 2017, 8:02 am
amanphoto wrote:Source of the post Yes the relief valve is open. I opened it to drain the water tank for winter.
A hose connected to it is fine and will not cause an issue whatsoever.
Postby bud37 » December 27th, 2017, 9:49 am
Midnightsun wrote:Source of the post
+1 Yup....check out your water heater at home.
Postby Viper » December 27th, 2017, 11:35 am
amanphoto wrote:Source of the post.......I was under the impression that nothing should be connected to the relief valve. It could cause a restriction and course the unit to blow up.
Nope. That's why the discharge port on the valve is threaded. They wouldn't do that if they didn't want anything hooked up to it.
Been thanked: 248 times
Postby mjk1040 » December 30th, 2017, 6:44 am
Relief valve drain hose is exactly what it is.
