Hiding tv cable
- rmeyer03
- Vessel Info: 1997 Carver 355
Hiding tv cable
Re: Hiding tv cable
This may help you out.
On the bridge, port side, remove the storage / speaker cubby. I believe there were four screws. This is where pretty much everything is routed.
I assume you already have figured out if you pop the back of the seat in front of the helm and remove the three plastic panels you can access all of the helm wiring. Getting from the helm area, to the "cubby" area is the easy part, use a fish tape and pull your wires. I always pull and extra so I can use it to pull future wires. From the cubby you can also get into your arch fairly easily.
The fun part is getting from the bridge down. In the cubby area, you will see the bundles of wires, throttle and shift cables and everything else. These drop down a chase that you can access by removing the salon rear port side speaker panel. If you don't have the removable panel, then the aft cabin port side closet back needs to be removed. Next, remove the base of the aft cabin closet. Then, access your port tranny area thru the really small access door in the forward wall of your aft cabin.
That gets you to all levels of you boat.
Lots of fun. Not easy but it can be done!!!
- rmeyer03
Re: Hiding tv cable
Re: Hiding tv cable
