Hot water for aft shower
NTL
Topic author - Scurvy Dog
- Vessel Info: 1990 Carver 3608
I have a 1990 3608 ACMY and when I am using city water hook up at the dock I have hot water for the aft shower but when out on the water and I am using the water pressure pump I have hot water in all other faucets except for the aft shower. I am assuming it is a check valve somewhere but I am unable to locate it. Does anyone have any ideas or thoughts? Thank you in advance for your help!
- Been thanked: 491 times
Re: Hot water for aft shower
Possibly the filter is slightly clogged and the aft shower is the farthest from the pump, thus not getting the water? Or the pressure pump needs a rebuld? It is really a simple thing to do. The standard "filter", more like a strainer bowl, is usually mounted close to the pressure pump. It's a little thing, clear plastic.
After turning off the water, unsrew it and clean it. If that wasn't it, you should be able to take out the pump and rebuild it fairly cheaply and easily. Just get the model number and buy a kit.
uaesi
- Vessel Info: 2004 466 Carver
