Would the aft bilge not be cooler anyway, only the gen there ?........
Viper wrote:Source of the post I asked if you have a generator but given that you have automatic transfer solenoids, that answers my question. I would use the generator for larger loads and limit inverter operation to smaller loads. Microwaves however, even though they can draw quite a bit, they don't get used for very long at any given time unless that's how you do most of your cooking. Generator or not, even if you only use the inverter for small loads, you must a wire size rated for the full load capacity that the inverter is designed to deliver (peak load).
You need to get the bank and inverter closer together. The Promariner 2000W for example draws 200 amps and requires 0 awg wire for a unit mounted 5 feet from the source with no more than a 10% voltage drop, so you can imagine what it will take when it's a 40 foot run.
bud37 wrote:Source of the post So after some more consideration of your situation, it seems that if you are changing from the existing house bank of one battery to four 6volt, the only way to have short runs at all would be if your new bank was between the engines and the inverter and charger were all in the engine compartment or very close to it.......seems you are stuck a bit.......is there a compromise that would meet both needs I wonder......
bud37 wrote:Source of the post I think moving the start batteries is the way to go....sounds like a good choice....maybe a small box to hold the starts above the house bank....just spitballin here..........
