Water in bilge
rmh
Topic author - Scurvy Dog
- Vessel Info: 1996 355 Aft Cabin
Water in bilge
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
Re: Water in bilge
SeaDragon
rmh
Re: Water in bilge
- AaHubb
Re: Water in bilge
..Aaron
SeaDragon
- Been thanked: 491 times
Re: Water in bilge
Not all boats sit in the water with the lowest point being the engine room. The front of your boat could actually be lower than the rear while static, especially if you've loaded it up beer in the fridge and tons of personal stuff.
Start with the shaft packing. rememeber, it should drip a litlle, unless they are "dripless" seals.
rmh
Re: Water in bilge
- Reelpriority
- Vessel Info: Carver 356 Aft Cabin
1999
Miss Judy, Murrells Inlet, SC - Been thanked: 4 times
Re: Water in bilge
We replaced the A/C unit which now has a composite pan and also made sure the drain fitting hose clamp was securely tightened. Most of the older Carver A/C units have steel condensate pans which fail at some point.
You may also want to check your 11 gallon hot water heater unit for tank leaks.
Murrells Inlet, SC
- DanM
- Vessel Info: Carver 396
- Been thanked: 35 times
Re: Water in bilge
Carver 396
SugarSand Tango
Santego
- Vessel Info: 1995 Carver 355 Aft Cabin
- Been thanked: 2 times
Re: Water in bilge
Iuka, Ms
1987 Carver Santego 2767
1984 Bayliner Capri Cuddy
2005 Bass tracker 1850
MissWhit's
- Location: Eisenhower yacht Club, Lake Texoma, Sherman TX
Re: Water in bilge
Lake Texoma, Denison TX
Port: EYC Marina
2001 406 twin 380HP 454 MPI
Users browsing this forum: No registered users and 45 guests
